You can select a suitable sport mode from the predefined sport modes.
          Depending on the sport, different information is shown on the display
          during exercise. For example, the sport mode specifies whether
          FusedSpeed
            TM
          or plain GPS speed is used. (For more information, see
            FusedSpeed
          .) The selected sport mode also affects exercise settings, such as HR
          limits, autolap distance,
          Alti & Baro
          mode and recording rate.
          In Movescount you can create more custom sport modes, edit the
          predefined sport modes and download them to your device.
            SWOLF is used to calculate swimming efficiency. It is a combination
            of swim time and number of strokes over a specific pool length.
          Additional options in sport modes
            When a sport mode is selected, keep
            Next
            pressed to access additional options to be used during your
            exercise:
          Using heart rate belt
            A heart rate belt can be used during exercise. When you use a heart
            rate belt,
            Suunto Ambit2
            gives you more information about your activities.
              Using a heart rate belt enables the following additional
              information during exercise:
            - heart rate in real time
            - average heart rate in real time
            - heart rate in graph form
            - calories burned during exercise
            - guidance to exercise within defined heart rate limits
            - Peak Training Effect
              information after exercise:
            - peak heart rate
            - recovery time
          Troubleshooting: No heart rate signal
              If you lose the heart rate signal, try the following:
              Check that you are wearing the heart rate belt correctly (see
                Putting on heart rate belt
              Check that the electrode areas of the heart rate belt are moist.
              Replace the battery of the heart rate belt, if problems persist.
              Re-pair your heart rate belt with the device (see
                Pairing POD/heart rate belt
              Machine-wash the textile strap of the heart rate belt regularly.
              Suunto Ambit2
              is compatible with Suunto ANT Comfort Belt.
            Adjust the strap length so that the heart rate belt is tight but
            still comfortable. Moisten the contact areas with water or gel and
            put on the heart rate belt. Ensure the heart rate belt is centered
            on your chest and the red arrow is pointing up.
            WARNING:
              People who have a pacemaker, defibrillator, or other implanted
              electronic device use the hear rate belt at their own risk. Before
              starting the initial use of the heart rate belt, we recommend an
              exercise test under a doctor’s supervision. This ensures the
              safety and reliability of the pacemaker and heart rate belt when
              being used simultaneously. Exercise may include some risk,
              especially for those who have been inactive. We strongly advise
              you to consult your doctor prior to beginning a regular exercise
              program.
              Suunto Ambit2
              cannot receive the heart rate belt signal under water.
              Machine-wash the heart rate belt regularly after use to avoid
              unpleasant odor and to ensure good data quality and functionality.
              Only wash the textile strap.
            Suunto Ambit2
            supports ANT+
              TM
            compatible heart rate belts and certain PODs. Visit
              www.thisisant.com/directory
            for a list of compatible ANT+ products.
          Starting exercise
          To start exercising:
              Moisten the contact areas and put on the heart rate belt
              (optional).
              Press
              Start Stop
              to enter the start menu.
              Press
              Next
              to enter
              Exercise
              Scroll the sport mode options with
              Start Stop
              or
              Light Lock
              and select a suitable mode with
              Next
              The watch automatically starts searching for a heart rate belt
              signal, if the selected sport mode uses a heart rate belt. Wait
              for the watch to notify that the heart rate and/or GPS signal have
              been found, or press
              Start Stop
              to select
              Later
              . The watch continues to search the heart rate/GPS signal.
              Once the heart rate/GPS signal has been found, the watch starts
              showing and recording heart rate/GPS data.
              Press
              Start Stop
              to start recording your exercise. To access the options menu, keep
              Next
              pressed (see
          During exercise
            Suunto Ambit2
            gives you additional information during your exercise. The
            additional information varies depending on the sport mode you have
            selected, see
            Sport modes
            . You will also get more information, if you use a heart rate belt
            and GPS during exercise.
            Suunto Ambit2
            allows you to define what information you want to see on the
            display. For information on customizing the displays, see
            Custom sport modes
              Here are some ideas on how to use the watch during exercise:
              Press
              Next
              to see additional displays.
              Press
              View
              to see additional views.
              To avoid accidentally stopping your log recording or making
              unwanted laps, lock the buttons by keeping
              Light Lock
              pressed.
              Press
              Start Stop
              to pause recording. The pause will be shown in your log as a lap
              mark. To resume recording, press
              Start Stop
              again.
          Recording tracks
            Depending on the sport mode you have selected, your
            Suunto Ambit2
            allows you to record various information during exercise.
            If you are using GPS while recording a log,
            Suunto Ambit2
            will also record your track and you can view it in Suunto app. When
            you are recording your track, the recording icon and the GPS icon
            are shown on the upper part of the display.
          Making laps
            During your exercise, you can make laps either manually or
            automatically by setting the autolap interval in Movescount. When
            you are making laps automatically,
            Suunto Ambit2
            records the laps based on the distance you have specified in
            Movescount.
            To make laps manually, press
            Back Lap
            during the exercise.
              Suunto Ambit2
              shows you the following information:
            - top row: split time (duration from the start of the log)
            - middle row: lap number
            - bottom row: lap time
              The exercise summary always shows at least one lap, your exercise
              from start to finish. The laps you have made during the exercise
              are shown as additional laps.
          Recording altitude
            Your
            Suunto Ambit2
            stores all your movements in altitude between the start and stop
            time of the log. If you are engaged in an activity in which your
            altitude changes, you can record the altitude changes and view the
            stored information later.
              By default, altitude measurement is based on FusedAlti. For more
              information, see
              FusedAlti
          To record altitude:
              Make sure that the
              Altimeter
              profile is activated.
              Press
              Start Stop
              Press
              Next
              to select
              Exercise
              Scroll the sport modes with
              Start Stop
              or
              Light Lock
              Next
              Wait for the device to notify that the heart rate and/or GPS
              signal have been found, or press
              Start Stop
              to select
              Later
              . The device continues to search the heart rate/GPS signal. Press
              Start Stop
              to start recording the log.
          Setting altitude during exercise
            Most of the sport modes allow you to set your altitude manually
            during exercise.
              To set your altitude during exercise:
              While you are in a sport mode, keep
              Next
              pressed to access the options menu.
              Scroll to
              Altitude
              with
              Start Stop
              and select with
              Next
              Set your altitude using
              Start Stop
              and
              Light Lock
              Accept with
              Next
          Using compass during exercise
            You can activate the compass and add it to a custom sport mode
            To use the compass during exercise:
              Next
              Scroll to
              Activate
              with
              Light Lock
              and select with
              Next
              Scroll to
              Compass
              with
              Light Lock
              and select with
              Next
              The compass is shown as the last display on the custom sport mode.
            To deactivate the compass, go back to
            Activate
            in the options menu and select
            End compass
          Using interval timer
            You can add an interval timer to each custom sport mode in
            Movescount. To add the interval timer to a sport mode, select the
            sport mode and go to
            Advanced settings
            . The next time you connect your
            Suunto Ambit2
            to your Movescount account, the interval timer will be synchronized
            to the watch.
              You can specify the following information in the interval timer:
              interval types (
              high
              and
              low
              interval)
            - the duration or distance for both interval types
            - the number of times the intervals are repeated
              If you do not set the number of repetitions for the intervals in
              Movescount, the interval timer will continue until it has been
              repeated 99 times.
              To activate/deactivate the interval timer:
              Next
              Scroll to
              activate
              with
              Light Lock
              and select with
              Next
              Scroll to
              Interval
              with
              Start Stop
              and select with
              Next
              Press
              Start Stop
              or
              Light Lock
              to set the interval timer
              On/Off
              and accept with
              Next
              . When the interval timer is active, the interval icon is shown on
              the top of the display.
          Navigating during exercise
            If you want to run a route or to a point of interest (POI), you can
            select the respective default sport mode (Run a Route, Run a POI)
            from the
            Exercise
            menu to begin navigating immediately.
            You can also navigate a route or to a POI during your exercise in
            other sport modes that have GPS activated.
          To navigate during exercise:
              While you are in a sport mode with GPS activated, keep
              Next
              Press
              Next
              to select
              navigation
              Scroll to
              POIs (Points of interest)
              or
              Routes
              with
              Light Lock
              and select with
              Next
              The navigation guidance is shown as the last display on the
              selected sport mode.
            To deactivate navigation, go back to
            Navigation
            End navigation
          Finding back during exercise
            Suunto Ambit2
            automatically saves the starting point of your exercise, if you are
            using GPS. During exercise,
            Suunto Ambit2
            guides you back to the starting point (or to the location where the
            GPS fix was established) with the
            Find back
            functionality.
              To find back to the starting point during exercise:
              Next
              Press
              Next
              to select
              navigation
              Scroll to
              Find back
              with
              Start Stop
              and select with
              Next
              . The navigation guidance is shown as the last display on the
          Using Track back
            With
            Track back
            , you can retrace your route at any point during an exercise.
            Suunto Ambit2
            creates temporary waypoints to guide you back to your starting
            point.
          To track back during exercise:
              Next
              Press
              Next
              to select
              Navigation
              Scroll to
              Track back
              with
              Start Stop
              and select with
              Next
            You can now start navigating your way back the same way as during
            route navigation. For more information about route navigation, see
            During navigation
            Track back
            can also be used from the logbook with exercises that include GPS
            data. Follow the same procedure as in
            Navigating a route
            . Scroll to
            Logbook
            instead of
            Routes
            , and select a log to start navigating.
          Autopause
            Autopause pauses the recording of your exercise when your speed is
            less than 2 km/h. When your speed increases to more than 3 km/h, the
            recording continues automatically.
            You can set autopause to on/off for each sport mode in Movescount.
            Alternatively, you can activate autopause during exercise.
              To set autopause on/off during exercise:
              Next
              Scroll to
              Activate
              with
              Light Lock
              and select with
              Next
              Scroll to
              Autopause
              with
              Start Stop
              and select with
              Next
              Press
              Start Stop
              or
              Light Lock
              to set autopause
              On/Off
              and accept with
              Next
          Viewing logbook after exercise
            You can view the summary of your exercise after you have stopped
            recording.
              To stop recording and view the summary information:
              Keep
              Start Stop
              pressed to stop and save the exercise. Alternatively, you can
              press
              Start Stop
              to pause the recording. After pausing the log, confirm stopping by
              pressing
              Back Lap
              , or continue recording by pressing
              Light Lock
              . After stopping the exercise, save the log by pressing
              Start Stop
              . If you do not want to save the log, press
              Light Lock
              Press
              Next
              to view the exercise summary.
            You can also view the summaries of all your saved exercises in the
            logbook. In the logbook the exercises are listed according to time
            and the latest exercise is shown first. The logbook can store
            approximately 15 hours of exercises with the best GPS accuracy and 1
            second recording interval.
              To view the summary of your exercise in the logbook:
              Press
              Start Stop
              Scroll to
              Logbook
              with
              Light Lock
              and enter with
              Next
              . Your current recovery time is shown.
              Scroll the exercise logs with
              Start Stop
              or
              Light Lock
              and select a log with
              Next
              Browse the summary views of the log with
              Next
          Memory left indicator
            If more than 50 % of the watch memory has not been synchronized,
            Suunto Ambit2
            displays a reminder when you enter the logbook.
            The reminder is not displayed once the unsynced memory is full and
            Suunto Ambit2
            begins overwriting old logs.
          Dynamic exercise summary
            The dynamic exercise summary shows the active fields from your
            exercise as a summary. You can browse the summary views with
            Next
            The information shown on the summary depends on the sport mode you
            used, and whether you used a heart rate belt or GPS.
              By default, all the sport modes include the following information:
            - sport mode name
            - time
            - date
            - duration
            - laps
              If you select cumulative ascent/decent as a display option, the
              data will only be shown if you have also selected best GPS
              accuracy. For more information about GPS accuracy, see
                GPS accuracy and power saving
            You can access more detailed data in Suunto app.
          Recovery time
            Suunto Ambit2
            always shows your current cumulative recovery time from all your
            saved exercises. The recovery time indicates how long it takes for
            you to fully recover and be ready to exercise with full intensity.
            As your recovery time decreases or increases, the watch updates it
            in real time.
            To view your current recovery time:
              Press
              Start Stop
              Scroll to
              Logbook
              with
              Light Lock
              and select with
              Next
            - The recovery time is shown on the display.
              The recovery time is shown only if it is longer than 30 minutes.
