1 / 4
Suunto Core Black Yellow
1/4
Money-back guarantee
30-Days Return
Warranty Repair
SKU: SS013315010
The traditional outdoor watch for off-grid adventures.
30-Days Return
Warranty Repair
SUUNTO CORE - THE OUTDOOR WATCH
Every great adventure starts from within. From a drive to seek out new places and discover new experiences. Your passion is our inspiration. Suunto Core is the essential outdoor watch with a pioneering spirit designed to bring out the explorer in you.
The award-winning Suunto Core gathers a range of data to help you navigate your way through the wilder parts of the world.
Altimeter
The altimeter features a range up to 9000 m (29 500 ft). It is ideally suited for all activities where knowing your altitude and ascent and descent rates is essential. The Core altimeter sports an altitude difference measurement that allows you to track your progress in terms of altitude climbed. The log recorder stores all your movements in altitude between the start and stop times, so you can re-live your trip at home - view graphs of changes in altitude during your treks, find out how much you climbed, the duration of ascents and descents, average ascent and descent speed and more.
Barometer
Suunto Core displays the current sea level pressure as a detailed graph, showing recording of the last 24 hours with a recording interval of 30 minutes. The weather trend indicator is a useful feature providing quick reference to check upcoming weather conditions. The storm alarm notifies you of a sudden drop in air pressure, which may be related to worsening weather conditions.
Automatic Alti/Baro switch
Suunto Core sports an Automatic Alti/Baro switch, a smart feature that senses your movement or lack thereof, switching between altimeter and barometer accordingly. When you’re climbing, it records changes in elevation. And when you stop to rest, it records changes in barometric pressure. A drop in air pressure while you’re sleeping under the stars will be recorded for what it really is: a change in barometric pressure, not altitude
Compass
The digital compass displays the cardinal or half-cardinal point and the North. The declination adjustment function allows you to correct the difference between the true North and magnetic North. You can also set it to track a certain bearing, which helps you follow a chosen direction in the terrain. The compass features a rotating bezel for traditional use (most variants), or a one-touch function that allows you to sight lock and follow a bearing.
Depth meter
Intended for snorkeling, the Suunto Core depth meter provides information on current depth and the maximum depth reached during your snorkeling dive. The maximum depth of the device is 10 m (32,8 ft).
Watch
Watch functions include time, dual time, date, alarm, sports chronograph, countdown timer and predicted times for sunrise and sunset for over 400 locations worldwide.
Suunto Core is available in a range of styles and materials.
PRODUCT HIGHLIGHTS
  • Altimeter, barometer, compass
  • Weather functions
  • Mountain & everywhere use
SPECIFICATIONS
  • Measurements
    49.1 x 49.1 x 14.5 mm / 1.93 x 1.93 x 0.57 "
  • Weight
    63 g / 2.22 oz
  • Bezel material:
    Aluminum
  • Glass material:
    Mineral crystal
  • Case material:
    Composite
  • Strap material:
    Silicone
  • Country of manufacture
    CN
TECHNICAL SPECIFICATIONS
  • Bezel material
    Aluminum
  • Glass material
    Mineral crystal
  • Case material
    Composite
  • Strap material
    Silicone
  • Weight
    63 g / 2.22 oz
  • Water resistance
    30 m
  • Battery type
    CR2032
  • User replaceable battery
  • Time, date
  • Alarm clock
    1 daily alarm
  • Dual time
  • Countdown timer
  • Stopwatch timer
  • Language
    EN, DE, ES, FR
  • Backlight
    electro-luminescent
  • Configurable backlight
    activation: 1 button, all buttons
  • Button lock
  • Display type
    matrix
  • Metric and imperial units
  • Battery indicator
    low battery indicator
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
BATTERY LIFE
  • In time mode
    12 months
COMPASS
  • Digital compass
  • Direction scale
    degrees
  • Needle
    north indicator
  • Compass accuracy
    5°
  • Compass resolution
    1°
OUTDOOR FUNCTIONS
ALTIMETER
  • Barometric altitude
  • Altitude graph
  • Altitude difference
  • Total ascent/descent
    air pressure based
  • Automatic alti/baro profile
  • Log recording rate
    1, 5, 10, 30, 60 s
  • Resolution
    1 m
  • Range
    -500 - 9000 m
WEATHER
  • Sunrise/sunset times
  • Storm alarm
  • Sea level pressure
  • Temperature
  • Temperature display range
  • Temperature resolution
    1°
  • Pressure resolution
    1 hPa / 0.03 inHg
  • Max weather recording length
    7 days
  • Sea level pressure graph
  • Weather trend indicator
DIVING FUNCTIONS
FREEDIVING
  • Depth meter for snorkeling
    10 m
Recommended products
VIDEOS
How to change the strap of your Suunto Core Classic outdoor watch -video.
See how to change a new battery to Lumi and Core.
Learn how to adjust the display contrast of your Core.
How to calibrate the compass -video.
Learn how the altimeter of your Suunto watch works and how to ensure a most precise measurement.
support for suunto products
SUPPORT FOR SUUNTO CORE
Find how to videos, FAQs, tutorial articles and detailed support information for your Suunto watch.
