1 / 10
SUUNTO D5 Black Lime
1/10
Money-back guarantee
30-Days Return
Warranty Repair
SKU: SS050191000
Suunto D5
Black Lime
Rs. 59,177
Easy-to-use dive computer with interchangeable straps.
  • Mineral crystal color display screen with aluminum bezel
  • Dive functions, and digital compass features with Suunto Fused? RGBM 2 decompression model
  • Maximum operating depth up to 100m
  • Up to 6-12 hours of battery life in diving mode
  • 5 dive modes(air, nitrox, free,gauge and off)
  • Customizable dive modes for your own display
  • Display up to 3 tank pressures with Suunto Tank Pod
    Choose Your Color
    Quantity
    Free shipping on orders of ₹16000 or more.
    Rs. 59,177
    Compare +
    30-Days Return
    Warranty Repair
    Wireless tank pressure support
    Extensive scuba and freedive features
    Digital compass
    Wireless mobile connection
    Vibration alarms
    Rechargeable battery
    Diving life made easy
    Suunto D5 is designed to be so clear and easy-to-use that you can just enjoy and focus on exploring the wonderful underwater world. When not diving, connect wirelessly to Suunto app and receive notifications from the applications you use. Play with style by choosing your favorite color or just by simply changing the straps to match your looks. Suunto D5 connects your two lives: the adventure under the surface but also the great experiences you can relive and share with your friends afterwards.
    iF Design Awards 2020
    BENEFITS
    EASY TO USE
    Follow your dive details on the super clear, high contrast color screen. Choose from 3 dive modes and browse the simple yet intuitive menu with three buttons to easily switch between views and settings. You can easily customize your own dive modes in Suunto app. Choose from different view styles and select the details you want to see while diving. By customizing your dive modes you can also define your settings regarding gas, algorithm and dive alarms. Keep your device easily up-to-date with SuuntoLink and make your dive life one step easier.
    DIVING LIFE MADE EASY
    Pair your Suunto D5 with Suunto app and stay connected with the diving community and the non-diving life of yours. Receive notifications to your mobile of the applications you use and never miss an adventure.
    Transfer your dive logs over Bluetooth to build an all-inclusive dive history to relive and share with your friends. With the location feature every dive and adventure is always on the map.
    Suunto app is available in the App Store and Google Play.
    MATCH WITH YOUR STYLE
    Change the strap easily with the clever quick release system to fit your style. Choose a color that matches your diving gear, or pick your favorite color silicone or leather strap to complete your casual style. To support your everyday usage, an analog watch face is now available for those appreciating the classic style.
    WIRELESS CONNECTIVITY
    Follow your gas pressure conveniently straight from your wrist. Get tank pressure on your display wirelessly by pairing your Suunto D5 with the Suunto Tank POD before diving. After dive review your gas consumption (when using Suunto Tank POD) in Suunto app and improve your diving.
    SPECIFICATIONS
    • Measurements
      53 x 53 x 16.3 mm / 2.09 x 2.09 x 0.64 "
    • Weight
      90 g / 3.17 oz
    • Bezel material:
      Stainless steel
    • Glass material:
      Mineral crystal
    • Case material:
      Reinforced composite
    • Strap material:
      Silicone
    • What's in the box?
      Suunto D5 Black Lime, USB Cable, Quick Guide, Safety leaflet, Display scratch guard sticker, International warranty leaflet, Suunto sticker
    • Country of manufacture
      FI
    TECHNICAL SPECIFICATIONS
    • Bezel material
      Stainless steel
    • Glass material
      Mineral crystal
    • Case material
    • Strap material
      Silicone
    • Weight
      90 g / 3.17 oz
    • Vibration alert
    • Water resistance
      100 m (ISO 6425, EN 13319)
    • Battery type
      rechargeable lithium-ion
    • Firmware upgradable
    • Time, date
    • Alarm clock
      1 daily alarm
    • Dual time
    • Stopwatch timer
    • Language
    • Backlight
      LED
    • Configurable backlight
    • Display type
      Memory in pixel
    • Display resolution
      320 x 300
    • Metric and imperial units
    • Battery indicator
      icon + dive hours remaining
    PHYSICAL SPECIFICATIONS
    • Operating temperature
    • Storage temperature
    BATTERY LIFE
    • Battery life (dive)
      up to 6-12 h of diving fully charged or up to 6 days in time mode
    COMPASS
    • Digital compass
    • Tilt compensation
      up to 45°
    • Declination correction
    • Direction scale
      degrees
    • Needle
      compass rose
    • Globally balanced
    • Compass accuracy
      +/- 15°
    • Compass resolution
      1°
    CONNECTIVITY
      inductive (Tank POD), Bluetooth Smart
    • Compatible with Suunto app
    • Watch customization
      Customizable with DM5
    • Compatible with DM5
    • Log transfer
      Bluetooth Smart / USB cable
    • Smartphone compatibility
      Most common models supported
    OUTDOOR FUNCTIONS
    WEATHER
    • Temperature
    • Temperature display range
      -20 to +50 °C/-4 to +122 °F
    • Temperature resolution
      1° C / 1.5° F
    DIVING FUNCTIONS
    BASIC
    • Altitude adjustment
    • Ascent time display
      0 - 999 min ( > after 999)
    • CNS/OTU (OLF) calculation
    • Customizable dive modes and displays
    • Decompression model
      Suunto Fused™ RGBM 2
    • Deep Stop
    • Dive history
      lifetime
    • Dive time
      0 to 999 min
    • Freedive
    • Gas consumption (real-time)
    • Gas max pO2
      1.6
    • Gas time
    • Gases
    • Gauge
    • Logbook bookmarks
    • Logbook memory
    • Logbook sampling rates
      scubadive 10s, freedive 1s
    • Nitrox (and air)
    • No fly time
    • No-decompression planner
    • Personal adjustment
      P+2, P+1, P0, P-1, P-2
    • Safety Stop
    • Surface time
      0 to 100 h
    • Timer
    • Visual style
      Graphical
    • Wireless air integration
      optional (up to 3 different tanks with Suunto Tank POD)
    DIVE ALARMS AND NOTIFICATIONS
    • CNS/OTU (OLF) 80% / 100%
    • Deepstop violation
    • Dive time
    • Gas time
    • High pO2 (hyperoxic)
    • Maximum depth
    • Tank pressure
    • Too fast ascent
    FREEDIVING
    • Depth alarm
    • Depth notify
      yes (5)
    • Dive time alarm
    • Freedive day history
    • Freedive number
    • Freedive total history
      lifetime
    • Surface time notify
    Recommended products
    VIDEOS
    You can now create dive modes for the Suunto EON family and Suunto D5 in Suunto app.
    Learn how to set depth notifies and a surface notify to use Suunto D5 for advanced free diving.
    Learn how to pair your Suunto D5 with the Suunto app for Android and how to get started with the app.
    Learn how to pair your Suunto D5 with the Suunto app for iOS and how to get started with the app.
    Learn how to use the compass bearing of your Suunto D5.
    DM5 is Suunto’s desktop software to customize and update the firmware of your dive computer. DM5 offers various customization options for Suunto D5.
    SUPPORT FOR SUUNTO D5
